WHere does the washer go?
2008 Nytro RTX
Norwich,NY
When you take off your secondary clutch and there is a washer behind it. DOes that washer go all the way to where the bearing are or does it stay right the back of the clutch?
I think I got it,I didn't put the clutch all the way in so it goes flush 2 the bearings then you tighten it down. Now how tight should I make it? Snug it or tighten it to where you can no longer tighten it anymore. I dont have a torque wrench so I hope it isn't a problem
The secondary bolt gets torqued to 46 ft./lbs. Most people tend to over tighten when they don't have a torque wrench. Use a short ratchet(around 5"-6") and tighten as much as you can, that should get you close.
It seems 2 b when I tighten it the clutch doesnt move back n forth. Before I did this it moved back n forth why would it do that? I am 95% sure im not making it 2 tight but i know thts not tight. Also there is 2 washer 1 thick 1 thin behind the clutch it self right? That goes on 1st then the clutch then the shaft with the sleeve n all the washers
No its not,the clutch was then I seen I had to spin it to get it 2 go all the way back,But if you push your clutch up and down when your looking at the sled it moves. When I tighten up the bolt to tight it doesn't do that. But im 95 % sure thats not the problem it has to be something else
Here is the reassembly diagram.
According to Port Yamaha that thing that looks like gets screw one says its the bearing housing but I never took no bearing housing off. When you take off the clutch what exactly comes out after you pull it off? only thing came off mine is a thin n thick washer
Ad as far as the sleeve n everything mine goes big bolt,really thick washer, thin washer, very thin washer then the sleeve. That isn't showing me the samething in above picture and I took it out and never took the sleeve off so I know for a fact I didn't mix this up. What the hell is going on lol
