jeff m
- Feb 7, 2014
my 07 phazer shuts down when i stop when it is warm. oil pressure sensor issue. where is the sensor located. also i was out yesterday in ideal conditions and the overheat light came on when i was riding hard on the trails could the water pump be going since if i stayed at a consistent speed even 5 miles down a lake at almost wide open it did not heat up at all.
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
Do you have the rad fan installed?
jeff m
- Feb 7, 2014
yes all the updates are done that i am aware of . the fan was running . i had to go off trail in deep snow to get the light off..
jeff m
- Feb 7, 2014
so i was doing some research and found that the ice build up can freeze over the heat exchanger . i never had that happen before but it makes sense. i have always had the ice build up but never froze over the heat exchanger. i bought some water wetter to put in but im going to hold off till the next ride.
Sensor is right next to oil filter.
