SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
So I started doing oil change and chain case. I drained everything and cleaned magnets and chain case.
Put it back together and added chain case fluid.
Then I found this under the sled........ Looks like a ball from a bearing.
Now I have to drain and remove the cover again to see where it came from.
Sled has 2934 miles, had 1685 when the sight glass failed (was posted).
So far it's the only one I have found.
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I wouldn't worry about it. You however might want to worry about it.
HURRICANE
That ball looks look je the plug from one of the crank rod journal oil gallery
Check your dollies or anything in shop with wheels like a stool. They like to shed the bearings.
Pstn head
The DREDFULL caster wheel bearing FREAK OUT !!! COLD SWEAT phenomenon. Lol
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Hhahaha it’s so funny , I think everyone one of us has made a freak out post with the dreaded caster bearing
SnoWarrior
- Jan 13, 2005
- Long Island, NY
Yea, I wish it was from a wheel.....that's the first thing I checked when I found it. Oh well, tear it apart and inspect. Not today 76 degrees here, the boat is calling my name.
Thanks for the replies, I will report back when I find something.
Keep looking at the caster wheels. There is nothing in your chaincase with a ball bearing that small.Yea, I wish it was from a wheel.....that's the first thing I checked when I found it. Oh well, tear it apart and inspect. Not today 76 degrees here, the boat is calling my name.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Isn’t there’s detent ball on the reverse actuator shaft?
krm
- Apr 22, 2016
- ny
just the springIsn’t there’s detent ball on the reverse actuator shaft?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Yes what he said!!!!!Check your dollies or anything in shop with wheels like a stool. They like to shed the bearings.
Same thing happened to me and it ended up being a ball bearing from my dollies
