NY AttakGT
Just was curious if anyone knew which rate Ohlins mono spring "696-15/62-519 was? Did not see it listed in most of the lists I saw on the site.
--Steve (O.C.)
--Steve (O.C.)
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Call mike carver,he may have your answer.NY AttakGT said:Just was curious if anyone knew which rate Ohlins mono spring "696-15/62-519 was? Did not see it listed in most of the lists I saw on the site.
--Steve (O.C.)
NY AttakGT
Thanks. Anybody else? Buehler?? Spring is "696 15/62 519"
--Steve (O.C.)
--Steve (O.C.)
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
As far as the Ohlins springs go the only numbers that really matter in regards to the spring style and rate are the 696-15. The other numbers are just production numbers. The 696 tells you the style of spring for application purposes and the 15 is the number that correspondes to the rate of the spring. A 15 would be a 6.3kg spring. As the number that defines the spring rate changes the spring rate changes by .2kg for each number. As a 14 is a 6.1kg and a 16 is a 6.5kg. Hope this info helps.
NY AttakGT
Thanks Kevin. Info is appreciated. 6.3 it is!
--Steve (O.C.)
--Steve (O.C.)
- 30K
