I was troubleshooting one recently and I had to keep taking the hood on and off multiple times.I would like the hood extension for a couple reasons at least.
-where I mounted my adjustable FPR, having the hood off makes it way easier to see and adjust
-being able to run the engine with the hood off makes it way easier to check for exhaust leaks
-leaning the hood up against the sled to be able to connect and run the engine can be cumbersome.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
I was thinking of spraying soap and water around to see if there is any bubbles around the bov. Kind of hard to do with the hood on. Also check for exhaust leaks. If I don’t ever use it for 30$ it’s on the shelf just in case I guess.I fail to see why one would need this extension.
You're not supposed to do a boost check on the sled gauge, or it will code out and need the clear code flash done to fix it anyway. There was a warning on this many years ago from TD back when they found out the hard way on this.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
I had one from Arctic Cat for my 1100 since I could not run the sled with the hood off. It was handy.I was actually on cat country and they have a 16 pin plug hood harness extension.It should be the same I have an email into them. I’ll give update when I receive an answer.
Turboflash
- Mar 18, 2019
- Southern MN
Cat p/n 1686-802.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I have one yet for my 15 Viper that I had bought from an eBay listing around 5 years ago. I have never used it yet but a harness extension would still be nice to have. I think when I compared it to the plugs on my Sidewinder, the main thing that was different were the raised areas & grooves on the plugs. They are located differently between Viper & Sidewinder.
I might sell that one if anyone is in need of one for a 14-19 Viper.
