Who here has Fix's Ram Air kit?
Mighty
Age
62
Grand Ledge Michigan USA!
22 Mach Z
23 Sidewinder SRX
Is it possible to switch back and forth with stock to compare or is there more to it than simply swaping the air cover tops?
Also, does it growl anything like the ECP kits for the RX-1?
i have it on,, it's not tha big of a deal to switch back and forth,, but it's louder then stock,, you hear the engine more,,, not sure what it did to the pipes but they also became louder,, so it seems. But for power,, well i had to add about 5 grams of weigth in the heal to get my RPM's ,, and it does pull harder the sled that i test against is about 3 sleds behind now,, and the driver of that one is a little guy compared to me,, hope all helps.
