pat the rat
- Mar 13, 2006
got my new belt from the reverse update,it was at the dealer but never had a chance to pick it up,the part# is 8gk-17641-10,not sure what the original one was but that's the one i got
MMStewy
- Jan 11, 2008
I too have been given a new (different) belt from my Ontario dealer under warranty to fix the problem. He never said anything about the shims though.
rhino_live
2mm sounds a tad drastic, the clutches being that far out of alignment only sounds like exesive blet wear and poor clutch engagement to me. in any case i don't use my reverse period and always disliked how it is a button that runs through tha guage pod, i've always liked a simple manual lever like on quad. anyhow has anyone actually tried machining their own shims for this? cause really i'm thinking like a half maybe 1mm would be more the sufficient to get the gear to engage.wayfastkev said:My had two shims in the secondary from the factory. I removed one shim and actually mine engages into reverse better. I dont use reverse much so I can live with the rockin thing.
Took another one apart and it only had one from the factory. Go figure. It basically just depends on how high you want to run that belt on the sheaves of the secondary. Do you want proper engagement or reverse? I think the shims are 2mm thick but I can measure it and post it for you.
McMaster Carr would probably have that in just about any thickness.Arctic Cat dealers also have them in half sizes.I believe they are used in thier new drive system.Forget what they call it.But it gets rid of chaincase.
RoicIND
Cannondale...
Are you reffering to the Diamond Drive?
Yes thats the name.Thanks.
- 6K
