Who makes the best aftermarket swaybar
Convert
Lakeville & Nevis, MinNoSnowta
Got my profit sharing check the other day! time for that new swaybar and straight rate springs I have the longer links already but have heard of breakage using the 13mm so plan on getting a 12mm and replacing the links with the originals if necessary. Any recommendations on the swaybar who makes the best one etc...
i had the 13 mm bar and broke it after 91 miles. Sno tek refunded me. The only other ones making a bar is Pioneer which are 11 and 12. Both had problems early on but I guess it was the hardening process and I heard it's been corrected. i got the 12mm bar now but have not installed it yet. If you are gonna go with the 12 you need to use the stock links. You could always get an 11 mm Yamaha 04 one but they may be hard to get. If you ride agressive then get the 12.
Sway bar
I have the Pioneer 12mm with 1400 miles and bno problems.
I have 2100 miles on the 11 mm Pioneer bar without a problem yet. I added the longer links at the end of the season but didn't get to try them. Overall very happy with my setup 8) 8)
