WHO"S RUNNING ASPHALT THIS SEASON TURBOS.......
FASTSLED
BOSTON.MASS
WHO IS RUNNING ON ASPHALT THIS SEASON LOOKING TO SEE HOW MANNY PRO OUTLAW SLEDS ARE OUT THERE TURBOS-SUPERCHARGERS-NOS ACROSS THE USA AND CANADA :nos
Slowly getting closer!
:Rockon:
this will be my first year running yammi on the grass. Always ran cats. I need to figure out the same, how i'm going to cool the sled.
outlaw turbo
flybu, we have a alumn radaitor with fan that mounts on the rear of a 136" or 144" LT this winter testing the prototype could drop the temp 25 degrees in less that 2 min after a pass. should work exc this summer ran sled just idleing 45 min could maintain a very low temp to cool to run. fastsled
Fastsled, I have all the stock heat exchangers in place yet and the thermostat removed. I will bypass the rear crossover tube in the tunnel and put a set of quick disconnects on. I'm hoping I won't see too high of temps (get towed to the line, leave the starting line at 100*F and hopefully not be over 200*F on the return).
From what I learned when I went a season ago you kind of want to avoid the return trip if you can. This is only because your temps get so much higher especially if you have to wait or anything then its really alot more work for your cool down system to get your temps down.
racing radiators
boys,with my cooling system you could drive your turbo to the beach ?? on boost !!!!!!! and not over heat the motor a lot of r&d when"t in the the cooling system radaitor , external pump , internal component modifacations you just drive it like a bike cool........
