wich one of these are the best upgrade
korgull
Canada, Québec
Canada
Yamaha Nytro xtx 2010
2010 nytro xtx brand new with A.D.Boivin ZX-2 suspension
ulmer racing brass ring ball joint $125 or hygear slycast A arm kitt $300
Is the 2010 nytro have the same A arms like the earlier one or yamaha corected their Geometri?
there is also ulmer full oilite upgrade and hygear needle bearing upgrade
I need to know who does what and wich one is better for the sled application 70% trail riding and 30% offtrail.
I already chose the roeser full plate, and probably the i.P ventilation, does the roeser full plate act as a floating plate too or must I add skinz concept float plate too?
The OFT relocator kitt
stock MTX skis
Bergstrom skegs triple point 8 inches+sky wear protector+shims+probably the ice graber
I must order before the end of the week
Thank you
2010 had the updated geometry. You are better off revalving etc to your weight and riding style IMO
Roest plate does not do flotation, and you cant add the Skinz one if you have the Roest plate on.
I would do the OFT relocator and OFT ROV as well.
