SharkAttak
shanksyamaha said:Thanks sharkattak, Im gunna order a set.
Anytime, the narrower ones go on a lot easier, have less drag, i know when i first put them on there wear down fast, then they stop, i haven't changed my out in 2 seasons and there still mint
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
SharkAttak said:narrower parts #'s for the 121" 8cm-47421-40-00 and 136" 8cw-47421-20-00
Shark....not sure if your numbers are same as mine,im sure they probably are same sliders....
On every slider Ive ever bought came this sticker...this is a number that would be found in the yammie accessory catalog. they are Graphite 121"
SMA-8CM92-70-HP
Dan
SharkAttak
ROCKERDAN said:SharkAttak said:narrower parts #'s for the 121" 8cm-47421-40-00 and 136" 8cw-47421-20-00
SMA-8CM92-70-HP
Dan
Thanks Dan, i just looked them up on the Yamaha website, maybe they changed the #'s ? i was looking under the 02 viper and 03 venture
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
I just use a planner and cut them down works great
