tvec
- Sep 21, 2006
I was planning on doing wildchild steering, but now I'm afraid it won't fit with my diamond s hood. I can't just dremmel the hood. Any ideas on what I could do??
cberg84
What is that light pod hole cover made of?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
TT - nice setup
sledskiing
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
I don't have any seat time with my Wildchild steering relocation kit, but will report when the snow flies.
AKRider - looking at the pic of your red #88, the surroundings look a lot like what nature looks like around here, if I did not know better I would have said that it was one of the mountain ranges nearby town there I live. Looks like a nice ridge to climb
RedRX1
For us guy's on shorties, is there any way this kit can be installed with the stock windshield still in place but cut down a bit?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
You can leave the windscreen in place, it needs to be trimmed to accept handlebars to rotate full left and full right. Depending on the bar riser system you use the speedo dash pieces may have to be moved as well. With my PowerMadd 4" riser block I had to move the speedo to another location as the lower bolts on the PowerMadd touched the speedo glass and would have broken it rotating the handlebars fully to either side.
rxrider said:You can leave the windscreen in place, it needs to be trimmed to accept handlebars to rotate full left and full right. Depending on the bar riser system you use the speedo dash pieces may have to be moved as well. With my PowerMadd 4" riser block I had to move the speedo to another location as the lower bolts on the PowerMadd touched the speedo glass and would have broken it rotating the handlebars fully to either side.
Yep, I experienced the same thing. My tall windshield would not work without being trimmed down so instead I just installed a short wind shield. That's a bad point for the conversion as the Apex uses a different style hood and relocates the headlight pod further forward to avoid the handlebar interference. I also had to relocate my gauge since the bottom of my "T" style post riser hit the glass and left a rub mark.
Sounds like your area in Norway is a lot like south central Alaska! That photo of my Vector is only 15 minutes and around 2700' in elevation from my home.
rx1mountain
How involved is this installation? How much do much do you have to disassemble to install this kit?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Seat, tank, tank covling and stock handlebars, steering post and relocation of speedo.
