LydonRX-1
- Nov 17, 2003
Has anyone tried this! I have dyno session booked for next week, and was considering installing the kit .
SUPERTUNER
- Aug 16, 2003
- Waterbury, Connecticut
- www.easterncycleperf.com
It will not work. All the new R1's are fuel injected with a "ram air" style airbox. The carbureted versions of these are also a ram air style airbox that is entirely different than the airbox on your sled. The carburetors are not the same style either in that the motorcycle has a full downdraft intake port on the cylider head. The RX1 has a downdraft cylinder head with a sidedraft intake manifold and sidedraft style carbs.
Your best bet for easy power is our Airfilter kits.
Freddie
Freddie
maverick
Lydon is absolutely correct for all the above stated reasons... However, a jet ket made for an FZ1 motorcycle should work. THe FZ1 never had ram air or fuel injection and is a much closer match in engine design than the R1 (both are based on the R1). In fact, it's basicaly the same motor minus the transmission. Try cross checking the part # for a FZ1 carb and an RX1 carb at the dealer. If they're the same, then it should work.
Max
Max
Frostbite
This is what I have been saying all along. I have bugged these guys (Dynojet) on several occassions to let us do the testing for them and see if their kits work on the RX-1. I would bet there is a racer or two that have already tried them and have not said a word. Here's a link to Dynojets website. It has horsepower and torque gains for each kit and the prices. PB
http://dynamic.dynojet.com/cfml/Jetkits/yamahajets.cfm
