BA APEX
looking for some info on holes in track.
I want to try studs on out side of track, but if i don't see an imprivement in takeoff on ice or lose on top end then I will be removing them.
will the holes that i leave make the track weaker and blow out??
right now i have 144 in the middle and on ice, it just spins. i may ad 24 or 48 more on the outside.
QCRider
- Feb 27, 2004
- Seacoast Region, New Hampshire
- www.myspace.com
My opinion is that the holes without studs in them are much less likely to damage the track than if the studs were actually there. Don't get me wrong, I stud my track out there too, but the stud is much more damaging than the hole.
LazyBastard
Every time I've ever had a track with studs in it, I've removed the studs. Never had a problem with the holes.
bashley
Shouldn't hurt at all. Mountain riders are drilling 3/4' - 1' holes in the track to lighten it up and reduce the snow build-up, and Doo has started doing it from the factory. I don't think little stud holes will hurt much.
Oak Hill
- Dec 19, 2004
- Owosso, Mi
- www.airtoolexpress.com
I have removed studs before and ran the track 2 years before I sold the sled, No Problems. I still think you will still spin on ice. You will need alot more studs.
BA APEX
thanks for you input guys, i'll throw in maybe 48 more studs and if i don't like the results, i'll pull'em back out.
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
BA APEX said:thanks for you input guys, i'll throw in maybe 48 more studs and if i don't like the results, i'll pull'em back out.
"I want to try studs on out side of track"
Where were you going to put the studs in the track? -On the outside edges? IMHO 48 won't do much of anything except ---put a ton of stress on each one and I think they would be much more apt to rip out (pull thorough). The "outside will help you in the corners -- If you really want to hook up better run them down the middle and run at least 96.
Tell me if I'm wrong, I just didn't want to see this guy ruin a track.
- Jun 28, 2004
- Clinton, Wi.
If you read his entire post you will see that he has 144 studs already.
Just a little help for ya'.
Dave
Dave
THKSNOW
Smooth Operator
- Aug 11, 2006
Thanks Dave ---Whooppse, sorry about that, got to read the WHOLE post...
- Jun 28, 2004
- Clinton, Wi.
NO problem. I sometimes skim and forget to read an entire thread, then realize I missed sumpthin'. It's ALL good!!
Dave
Dave
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
BA APEX said:looking for some info on holes in track.
I ran 168 in the middle, didn't like the added push in the corners and re-located the center most studs, to the outside. Yep, you read that right, added push.
