FX4
JUST WONDERING IF ANYONE HAS PUT THE BIGGER GAS TANK FROM A 2006, 2007 APEX ON A 2011 APEX. I HAD A FRIEND RUN OUT OF GAS TWICE THIS SEASON WITH THE SMALL 33 LITRE TANK. CAN ONLY GET ABOUT 106 MILES WHEN RIDING HARD.
THANKS
THANKS
I would say no, because of the power steering motr is in the way.
Greasemonkey
Like the boss said, the tank was made smaller because of the power steering box.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
MrSled said:I would say no, because of the power steering motr is in the way.
X2
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
No room because of eps
I ran out x 2 also ,
Can't go Sudbury to Shining Tree any more !
Can't go Cochrane to Lasarre , no gas in Laraine
110 + MILES PUMP TO PUMP
82SRX500
Remember, the 2006-2007 gas tanks have larger capacity than the 2008-2010 based on them putting a plastic liner inside the tank for emissions. I ran 2006 gas tanks on my 2008 Apexes fit perfectly and I gained a gallon+ of fuel doing this. Has anyone cross referenced the part numbers of the tank or tried an 2006-2007 tank on the 2011. With the seat off they look the same.
cookster
Hate to say it but was one of the reasons i switched brands. no good when you can`t ride the north in ontario. not everywhere has fuel stations every 80-100-110 miles depending on the snow amount on trail. it was a sad day but needed a upgrade.
kviper
Yamaha used to make the two small can's for the Nytro that had there own mount and they mounted to the side of the tunnel near the rear. I think they were one gal on each. Don't recall seeing them in the accessory catalog any more though?
