Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Launch Control! In my humble opinion this is the only thing missing to make it a perfect beast! I'd be the first to buy a plug and play unit and not some cobbled makeshift msd unit.
And Yamaha if you're listening..........Please do not throw on a cheap every third row clipped track on a high performance snowmobile ever again. Fully clipped or nothing.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Header, on a turbo? Not sure what you mean.
As for every 3rd window clipped, I agree the fully clipped are overall best, but I will say the slide life and rolling resistance of these sleds is impressive(compared to my doos) so I dont worry as much about fully clipped as I normally do with doos.
Im sure we will see launch control come out down the road with these tunes....I will be first to get that option too!
Dan
Dan
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
edited thx for clarification on simple 4 stroke turbo principles Rocker.
Credit for 2 out of 3?
Credit for 2 out of 3?Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
what is launch control ?Header, on a turbo? Not sure what you mean.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Build boost off the line.....for drag racing.
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
Have:
TD Powertrail (ordered)
TD Modified stk muffler (ordered)
TD Clutch Kit - Dalton weights and both Primary and Secondary Spring
TD rollers
TD Belt adjuster
Thunder Glide washers
UpNorth LinQ dual mount
Powertrail handguards
Will be ordering:
CAI
Axis shocks
LinQ SR21 bag
What am I missing????
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Is launch control different than anti-lag?Build boost off the line.....for drag racing.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Launch control, like the msd launch master, is just an rpm limiter for consistent launches. Can be used on a naturally aspirated or boosted engine.
True anti lag controls the launch rpm and launch boost level by messing with the timing and fueling. Causes the rich fuel mixture to ignite in your header and spool the turbo.
- 27K
