kingedwards99
Today i was getting my heatexchanger welded (took off Battery cables) so it was up in the air on the in the back, when i put in the coolant i spilled a little here and there, hooked the battery back up and it turned over but would'nt fire, and went i would quit trying to start it i'll say at the end of strating it, i would here a click. Any Help would be appreciated.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
hopefully you didnt fry your ecu you should remove it from the sled whenever welding on it...but, starter relay most likely got wet...
nytro addict
Do you have the kill switch on? Did you you see if the battery is fully charged? Did you check your fuses? Just some basic ideas so far.
usafracer
Is the fuel pump kicking on?
kingedwards99
usafracer said:Is the fuel pump kicking on?
Yes
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
sj said:hopefully you didnt fry your ecu you should remove it from the sled whenever welding on it...but, starter relay most likely got wet...
seen guys do that. I would check the ECU first.
usafracer
Then next step would be check for spark.
kingedwards99
You guys gave me a scare for a minute with all that ecu talk. I could'nt even sleep last night, ha ha, The starter relay was wet with antifreeze so i blew it out and added di electricial grease, should be back on the trail this weekend, thanks for the help guys
