yamahahaha
does replacing a relay fix the problem? cuz i had this happen to me last year. i rode 30km to were we were meeting, ate breakfast and came back out and it wouldnt start. then finally went. i got it fixed but if i leave it out in the cold/ something will that happen again?
Nytroman
- Dec 12, 2007
- Prince Albert, Sask
- 2008 FX Nytro
That seems to happen quite often on the Nytros as well as the Apexs. It is basically always the starter relay or the fuel pump relay. I always carry a spare of each with me. They tend to get moisture inside them and freeze up. Slap a new one in and she always goes. After the old ones warm up they will also work because the contacts will be unfroze. If the starter just clicks then it is the starter realy and if the pump does not cycle then it is the fuel pump relay. If you can't tell which one the 4 relays the fuel pump relay is, put your hand on each of the 4 relays and turn the key on, you will be able to feel the fuel pump relay click when the key is turned on.
2008 Nytro RTX
Also a way to help the fuse it put a better screen on your hood to keep snow out of there. I put pet screen on mine and it looks like it belongs,Id show a picture but my phone is in the car. But by doing this you will keep the snow out
alsops
- Feb 17, 2009
- Headingley, Manitoba, Canada
- liverpool.com
- 2009 Nytro XTX
2021 Sidewinder XTX LE
Hard starting
took about four cranks yesterday -15'c
Battery fully charged
Took it for a ride and idling was ok, but as soon as I tried to give it gas it spluttered and almost stalled. Had to feather the throttle?
It has new gas and was just given a pre inspection and oil change etc.I checked the oil level and it was showing high... above the mark, is this a problem?
winner
- Nov 26, 2009
Make sure it idles till light goes out then it should be good to go
chevmal67
Re: Hard starting
how did you check your oil? When checking dont screw it in, if you did it would read high.
alsops said:took about four cranks yesterday -15'c
alsops
- Feb 17, 2009
- liverpool.com
- 2009 Nytro XTX
oil level
Yes I didn't screw it in and it was showing high.
The dealer did the oil change.
