woodys 128 template
gibb666
Ontario, Canada
Hey guys, im looking for a woodys stud template, 15x128. Apparently they are back ordered until the end of December, wondering if anyone has one they could scan and send to me.
just my .02 ---- always seemed better to make your own pattern. Never was happy with the woodys, or others out there. Just make your own.
Tod
I think i probably will, its for a 2011 nytro xtx, running 114 all doubles up the middle. do you just make a template for 3 spaces then flip the template over for the next 3 and so on?
studs
iam having the same problem the other thing i was wondering if i was using a template i would mark the first set of holes then which way do u spin the track and place the template on again to mark the second set of holes and so on so on ....
Gibb666....if you have a xtx thats a 144 track.So you need the longtrack template not the 128" one.Basically you do one double backer per lug which will give you 114.But you want the backers alternated to give you the most scratch lines.
Apexman...i always move track in the forward rotation and mark next set behind that with template #'s or lettters facing forward as your looking at it.Most templates it doesnt matter but if its a V pattern you would want to do it like described.
