grader
you have figured out the problem, no power to the fuel pump. something you did, moving wires etc. allowed the power to flow. not knowing exactly where or why is the problem now. there was a post on this site a while back about taking apart the wiring harness and finding multiple ground wires coming from different areas and some having corrosion. this might be your problem. do a search in the apex forum about this topic. for now, if your still riding, i would run 2 wires direct from the battery, pos and neg to the pump. wire them in to run the pump using bullet connectors but leave them unplugged till you need them. this will get you home at least.
