Blue shadow
Last year at idle it read 13.5 a/f when I put it away . I just started it up and now its reading 5.5 a/f at idle .Did a free air calibration and still the same.I just replace the o2 sensor with a new one and still the same reading 5.5 a/f at idle.What could be wrong ?thanks
mtdream
what is it reading @ 20% throttle and 50% and WOT?
FLYBYU
It lost it's program. You need to plug it back in to computer and set it to the right fuel. It's not reading gasoline.
big_red1a
It can read afr or lamda you have to set it to afr
Blue shadow
Thanks I will try that.
Blue shadow
will I have it up on the computer but I cant find were it says to change to gasoline.On top it says info,input,min.hole,max.hole,alarm,and colours.Down on the bottom it says update firmware. what to do from there?thanks
Blue shadow
Do you have to hook up the Lc-1 with the XD-16 on the computer to change to gasoline?I was trying only with the XD-16 gauge
Blue shadow
ALL FIX ,had to program the LC-1 OVER not the XD -16
