harryamaha
I've been searching for a gps system with satellite radio and the outcome has been limited. I found a bushnell that looked promising but has been discontinued and terrible reviews. Other than that there appears to be nothing for snowmobile? There is the garmin zumo 550 and 650 for motorcycle that from what I've read will work but what is the service like in canada for XM? XM and sirius have joined but is it still seperate for service? What is the sound quality/volume and service in Canada for the zumo 550/650? Does it have external antenna/speaker/audio output. Right now I use a stilletto 2 with antenna in the headphones but not compatible with a helmet and I would like an all in one unit. I have posted this same question in the gps/maps section but I'm sure some of you guys in the mountain areas might be more experienced in this area and more likely to see this thread. Thanks
Talisman44
- Nov 25, 2010
I have been running a Garmin 476 for the last 4 years with no problems. I have xm weather and radio on it through the weather antenna. use it in the caar and boat. I have not used the radio on the sled yet but there is a mini RCA jack on the back that you can plug into.
