yamadog1
guys that run it how does it work being 1/2 to 5/8 inch longer then stock
8DN?
8DN?
sherlock29
I've only run this belt on both my apex's since new... love the belt. it is a softer compound, but i have better clutch engagement, less heat, and less belt dust. just changed one out on the 40th 4000 miles and still using as my spare.
i personally like alot
tdlong98
- Feb 28, 2010
I think it is soft. It holds up well but the stock belt is faster with my clutch kit
yamadog1
belt
hey tdlong98 do you think the 1/2 inch longer is the reason it's not as fast?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The extra length will increase the holeshot if you have proper traction. I still like the 8DN belt because it's hard to beat for its longevity.
tdlong98
- Feb 28, 2010
Re: belt
Maybe. I did not notice it was longer. I would get 116 mph on the dream o meter vs stock belt I got 124 mph. I might be getting a little slip from 10 to 30 mph with the stock belt too.
yamadog1 said:hey tdlong98 do you think the 1/2 inch longer is the reason it's not as fast?
- 7K
