xtx 8 inch billet wheel ..
so what size would you guys suggest getting? i wouldent want to be bottoming out when riding..thanks
I snow checked an xtx also and saw the larger wheels last night at the show. I thought about getting some but it seems to me that if you put the bigger ones on the back, it would defeat the purpuse of the 6 degree tip up. Wouldn't the track be closer to the ground on the tip?
marsh
in most cases, larger rear wheels require ( and use) an offset axle so that the bottom of the now larger wheel is at the same height as the hyfax
the exception to this is using oversize wheels near the front of teh skid to take some load off the hyfax in a high wear area
Ramb
It looks like the ones from yamaha are just the wheels
They are on yamaha's website under accessories. It just says large and small. It doesn't give measurements. At the show it looked like it was 7 or 8 inches.
