XTX high altitude????
rough rider
minnesota
I have a stock xtx except for a skins exhuast, I have 14.5 rollers in clutch, Im going out west to ride at 8-10000 feet, I have heard that the smaller rollers you will loose rpms at top end, I want to keep the smaller rollers in to smooth out take off, I am going to remove all rivits from weights, what color primary spring and helix angle would work best at this alt??????
this is what i did to my 2011 xtx:leave secondary alone stock primary spring use a 10.3 mm weight on outside hole . was out west myself with this set up pulled 8900 up any hill worked great u really should gear down to a 19 drive gear i didnt do that . next year i will gear down and put on 1.75 backcountry track !!
10.3 steel or aluminum?
