XTX sidewinder
LAKECITYAPEX
northern NY
What is the difference between a 2017 Sidewinder LTX-LE and an Xtx-Le besides the 1.75 inch track on the XTX-LE. Is the gearing the same? How much is a 2017 Sidewinder XTX-LE 1500 miles worth?
If you are talking the XTX LE 137 other than the track the QS3 shocks are not the kashima coated QS3R's with separate rebound adjustment. They still have rebound adjustment but they adjust based on how you have the compression adjusted. Stiffer compression will result in stiffer rebound. If you like to really fine tune your shocks then you will like the R's better. Everything else on the sled as far as clutching, gearing and spring rates are the same. I have the XTX LE 137 and I put an Ice Attack track on it. I don't mess with my suspension at all. I'm a set it and forget it guy and having the three settings on the front ski shocks and the rear most shock suits me just fine. Either shock pkg is much better than any shocks I ever had on my Doo Xpkg sleds. How much is it worth? I have seen them for around 12,000 used. I have no idea if that's a good deal or not but nobody is giving away used Winders.
smaller drivers? Ive heard its the slowest of them?
Not true with the LE 137" track. I think the longer track versions you might be right but the LE 137 has the same drivers, gearing and clutching as the LTX LE.
Isn't NosPro running ~130mph on a 141 XTX? I know lots of tuning, but still.
Spec sheets posted in Stick thread. 21/41 gearing
you have a point there.. nos pro says his is faster? dunno
I believe his top speed was 135mph speedo and 131 gps last year. We were at my cabin testing clutching. 141 xtx with stock gearing.
Yes, 130gps, 135 mph on speedo. 21/41 gearing with stock drivers 141 XTX SE. (Clutching stock has overdrive, but I machined mine for more overdrive. EVO stage 4, EVO exhaust and good clutching to get me there)
