Will the XTX skid bolt into the FX or are the mounting locations different?
If they're different has anyone done this swap and can you use any of the front or rear mount locations or do you need to make new holes?
If you need new holes can you make them in the existing plates or do you need to install all new mounting plates??
I ws considering an XTX skid swap instead of extending the FX skid as I have heard good things about the Mtn Tamer conversion using the XTX skid??
I'm not all that thrilled with the Fx skid either....
