extreman1
can i use 1.5 inch studs in the nytro xtx with out ripping out the heat exchangers or doing any damage
deanhell
Are you using the stock track? If so, use 1.325". I have 114 down the middle of my ripsaw and it hooks up fantastic. Also, I have bent a couple of studs and would be afraid of tearing a 1.5" out of the track.
sleddingfarmer
I'm running 1.45 megabites. There is more room available but not a ton. If you do it just run your track tight. If you take out that heat exchanger you'll regret it...its quite the job to replace it
YamahaFreak
The Pen is Blue
- Nov 26, 2009
- McHenry, IL
- Sr Viper XTX SE
1.5's will work, just get the taller nut...This is my opinion but its been working great and I haven't broke/ripped/bent one yet!
