y pipe replacement
Ken Talaga
Age
62
Bay City, MI
05 rs rage,06attak and 06 rs venture
I have a 2006 attak. the donuts went out and has worn the y pipes. has anyone seen or used the fxgarageworks braided flex pipes? It eliminates the exhaust donuts. Or should I switch to stainless pipes?
I just installed the FX braided flex pipes on my brother's 2009 Apex. Its a job I will tell you that. Cut/fit, fit, fit/file adjust etc.
It is not a hard job, just time consuming and sometimes frustrating. Need quite a few tools and lots of patience, not for everyone.
yes know what you are saying. I watched a video on how to install lot of adjusting
Hi Ken
My name is Kevin from F/X Garage Works. I put the kit together to eliminate the donuts and all the maintenance of the exhaust. By buying new or used “Y” pipes weather they are titanium or stainless you are going to run into the same out come. Damaged pipes ! Your “Y” pipes are the perfect candidate to in stall the kit and never have to touch the system again. If you have any questions please contact me through the web site. fxgarageworks.com. Thanks. Kevin
