Aspx
- Jan 8, 2022
- Altona Manitoba
- Yamaha Apex gt 1000 2007
I have a Yamaha Apex gt 1000 2007 it won't start not even the gauges are lighting up I heard it could be the kill switch will check that today any other suggestions?
Battery connections?
Aspx
- Jan 8, 2022
- Altona Manitoba
Battery is not good so I am going to put a new battery in
check the starter solenoid while you are in there as any corrosion on the fuse contacts or starter wires it can cause issues as well.
Aspx
- Jan 8, 2022
- Altona Manitoba
Starter solenoid is brand newcheck the starter solenoid while you are in there as any corrosion on the fuse contacts or starter wires it can cause issues as well.
check the part # as the rs venture/vector one looks the same as the apex one but it is wired different.
Yup. Double check if its the correct one. Make sure the the fuse on the front side is powered up and the fuse on the starter side is a spare meaning there is no power.
Aspx
- Jan 8, 2022
- Altona Manitoba
Do you know what the green relay is for beside the starter solenoid ?Yup. Double check if its the correct one. Make sure the the fuse on the front side is powered up and the fuse on the starter side is a spare meaning there is no power.
earthling
Thats the main 40amp fuse if you are looking at the picture.Do you know what the green relay is for beside the starter solenoid ?
Aspx
- Jan 8, 2022
- Altona Manitoba
I check the fuse and it is blow I connected it together and I have now power to my gaugesThats the main 40amp fuse if you are looking at the picture.
earthling
Congrats!
Aspx
- Jan 8, 2022
- Altona Manitoba
Still won't start shows code 12 and 22 I know 22 is because I have the airbox off and the sensor unplugged
earthling
Aspx
- Jan 8, 2022
- Altona Manitoba
Do you have a link where I can buy the crank position sensor?Code 12 is the crank position sensor. You can get info here.
