n.e.mich
I recently bought a 2007 Attak that came with the saddleless wide mountaian skis installed. I removed them and put on the stock skis. My question is, what other sleds will these fit? They have a longer mount bolt sleeve with another bushing on both ends.
A guy that owns a 2001 SXR wants them but is unsure if they will fit. Thanks in advance for any help!
they will bolt right onto his sxr. should even be the same height as his stock skis. brother's have a set each on a 2002 viper and 04 rxwar. putting a set on dad's 05 sxventure this fall.
n.e.mich
OK, thanks!
Super Sled
- Feb 25, 2009
- Summit X
Btw, why would you ever remove them? They will steer your sled night and day better than the skinny stockers. I recommend putting those Yammi Mt skis right back on
There and don't give it another thought. Mountain ski (not the new one, but 05 - '10 mountain ski) is best ski Ysmaha has ever made IMHO, hands down.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Super Sled said:Btw, why would you ever remove them? They will steer your sled night and day better than the skinny stockers. I recommend putting those Yammi Mt skis right back on
Ya, what he said. The MTX ski is the best Factory ski. They have a nice 1"+ deep keel and do very well on trails, especially trails with loose stuff in the corners where the short track ski will push bad.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Are these the mountain ski's your talking about? If not, any idea what they are?
Been thinking of selling one set of these, either my stockers or the set beside them?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
No Irv. The mountain ski's they are refering to are really wide. Your's look like the early versions used on the Mountain max's. I must also add that they look like clown shoes.....Might work well but are butt ugly. The new one's that is.
n.e.mich
Here is a pic when they were installed.
n.e.mich
In comparison to stock skis[/img]
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
IRV those ski's where the wide ski's you could get for the trailing arm sled they should be 5.5'' wide if you shim them they do work well on your sled. also they are made by USI
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
n.e.mich said:![]()
PM sent
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
darv said:IRV those ski's where the wide ski's you could get for the trailing arm sled they should be 5.5'' wide if you shim them they do work well on your sled. also they are made by USI
Thanks Mighty and Darv, I need to get rid of one set and by the sounds of things, I'll be getting rid of my stockers.
