lund
Ruckus said:Yep, a 100+hp Phazer with a better rear skid would be awesome. There is 50 lbs to be saved on the Phazer with ease.
Lets face it though, if 4 stroke is the direction Yamaha is going to continue with, there's no way they will be able to come near a 2T in weight. The motors are bigger, have more rotating mass, they can't spin backwards so you need a reverse mechanism, you can't pull them over so they need a starter and battery, to make them comparable to 2T of the same cc's they need to be boosted, which adds more weight and kills the fuel economy. So right off the bat you have 30-50 lbs more sitting over the skis. The rear exiting exhaust forces the gas tank to sit high above the tunnel and further increases the center of gravity and we all know how much ice it adds to the rear end. They are going to have to either go back to 2T or re-engineer and lighten the entire sled to accommodate the heavy engine. I really can't see it happening. Now, if they offered a multitude of sleds on one basic platform with a choice of 2T, 4T and boosted 4T then they would definitely have a winning combination. As it stands, these sleds will always perform better on a hard surface. They don't seem to be engineered to deal with the realities of soft snow. Someone tell me if I wrong.
I don't agree with what your saying.
To be competitive Yamaha can use their 4stroke, there is a market for it even in the mountian's. But they need a completely different line of thinking and a devoted mountian R&D team.
Proof is in the pudding, A/C dominates the western market as a mountian sled builder, ahead of BRP for a reason. The best mountian R&D team in the industry. Check out the 1100 A/C and compare to the Nytro, there is no doubt at first glance the 1100 scream's "MOUNTIAN SLED".
If that's not a wake up call for Yamaha, i guess the mountian guy's are out of luck.
