Bill-winnipesaukee
- Feb 21, 2018
- Alton, nh
- 08 Yamaha rs venture 2up
05 Yamaha rs rage 1up
Hello Guys,
Had a few idler wheels that were noisy. Got bearings to replace, but when i take off the idler wheel, the fitting / bearing are staying together. There is no retaining clip to take off, so not sure how to separate the bearing. I have tried to drive the bearing thru with a hammer and a socket around the right size... See pics, any ideas, let me know, thanks!
Bill-winnipesaukee
- Feb 21, 2018
- Alton, nh
Bill-winnipesaukee
- Feb 21, 2018
- Alton, nh
those are the stock wheels with the non replacaeable bearings. you can rinse those bearings out with brake clean and see if they turn smooth. if they do, repack with grease, re install seals and reinstall. if they do not turn smooth when clean, just buy an aftermarket wheel with bearing and snap ring to install. part of why i keep spares at home and in the trailer for my sleds.
Bill-winnipesaukee
- Feb 21, 2018
- Alton, nh
Makes sense - will try the brake clean for this weekends ride. That said, how would i detach the factory wheel from the support? I already replaced one with a wheel, and it came right off, this one is different for some reason...
it is just corrosion holding it onto the mount. happens to mine as well when i have not had them off on a few years.
kirkswim
- Jan 11, 2009
- sudbury ontario
- Yamaha RXWarrior
1” hardwood dowel place wheel over a vice and smack the down good. Small sledge or 24oz or higher hammer couple shots.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
If that's the only one that's bad, you can get a later year (i.e. 2012) stock wheel that does have replaceable bearings. If you have more than one or two, I'd replace them all with oversized 135mm wheels to help sliders last much longer. There are the Excell wheels https://www.excellmotorsports.com/X-Wheels--wheels
or there is another that looks like the stock Yamaha wheels made by Kimpex (04-4135-20). All have replaceable bearings and either cost the same or less than Yamaha's.
Gotrek
- Dec 28, 2019
- Winterpeg
- 2008 vector rs l-tx
I would not use brake cleaner as it will wear out the seals. Use WD40 as your cleaner of choice. Then repack the wheel with Grease.
i always lube the seal lips with grease when i pack them.
I have used brake clean and WD40. No matter what you use the seals always out last the bearing.
TinMule
- Feb 23, 2020
- West Nipissing, ON
- 09 Venture RS
07 Venture Lite
x2...
... i would replace that wheel so its off your mind for a while
Yammer on the Rock
- Mar 16, 2008
- NL
- Venture Lite
