Petterssonmotorsport
- Nov 2, 2012
Hello, I have a Yamaha rtx se Nytro 2009 that im going to race with.. Any one here who race with Nytros??
My set up
Hauck full system
KN air filters
Powercomander Usb ,ned to order the Autotune to it.
wounder what springs / helix and whight i should put into the clutch..
Smaller gear in the chain case?
Im going to drive both upphill and cross
Thanks / Nicklas Sweden.
My set up
Hauck full system
KN air filters
- Nov 2, 2012
I have found out that my Power comander USB don´t working with auto-tune so i have order a sensor and will map it by my self...
Any one here Drives a Nytro with Power comander 3 USB ??
My sled.
My sled.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
I didn't think the autotune would work with the pc3?
- Nov 2, 2012
No. it dont works... I have order a extern sensor and gauge.. then i have a digatron dt54 with exhaust temp and a logger.
anyone knows a MAP ready to use or do I have to mix one by my self?
Thanks.
Thanks.
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
Grass drags runs very well, haven't tried any sno-cross races with it, I bet I would pull a great holeshot in sno-cross, but would need to shed about 100 pounds of sled weight to stay competitive with that type of terrain with the lighter sleds. Some day I hope Yamaha engineers can develop a strong chassis designed for sno-cross that can dominate the circuit. 4-strokes took over in motocross, but certainly not in the sno-cross. If Yamaha ever decided to put their R&D folks together with sno-cross as a goal, it could happen IMO.
Box in the spindles and subframe to start.
- Nov 2, 2012
"Box in the spindles and subframe to start."
Where exactly ?
Yes the Yamaha is heavier than the last seld i ran a 09 Ski-doo RS 600 But i think its cooler to drive yamaha becus its a 4 stroke and almost no one drive Yamahas in snoX so.. its good for yamaha to get some sled out on the trak´s, you can drive fast on a Yamaha for shore =)
Apex2006 - Do you race grass with your sled?
Where exactly ?
Check out the grizztracks gusset. Too many options for spindle and control arm reinforcements to list, but all are DIY.
Alatalo
- Jan 11, 2005
Make sure to order couple of spare center swingarms as well. Since they do not last long during inspired trail riding, there is no way you will make one full snocross season without swapping them couple of times.
- Nov 2, 2012
problem ( raced last weekend)
Help!
did the first race last weekend.. the sled run very baad.. here is a video
http://www.youtube.com/watch?v=HhkDnuSu9J8
ran with Pc 3 and ullmer map Hauck full exhaust and KN filters.
Dont know whats wrong.. a damage wire?? the killswitch is okey.
Sometime the oil lamp did light but not every run
thanks // Nicklas
Help!
thanks // Nicklas
- Nov 2, 2012
may found the problem, a ground wire to the PC had a litle damage so will fix that tomorrow and take the sled to the track this weekend, Hope thats the problem.
- 26K
- 11K
