Todd Sanford
- Oct 12, 2014
- RX1 2003
Will 2005 warrior skis bolt up to 03 RX1? Got some in great shape for free. If so any choice of runners? I have had good luck with double downs on other sleds, but don't want this tank pushing
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
yes the 05 warrior skis will bolt up to the 03 rx-1. You will need the mounting bolt from the 05 ski as the 03 mounting bolt is shorter if i recall correctly. Both skis use the same skags, so you can use what ever runners you had for your 03 skis.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
the one ton should not push the only prob i had was steering was too heavy. if you shim the skis that lessens i never needed dual carbides on my rx 1 ton either. duals will cause pushing to be more probable then singles. id try 6" stockers first. or longer if studded.
TRUE BLUE SINCE 1980
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
I am a fan of shimming the skies, I think it helps. Also if you get some pressure off the ski's you may want to remove some of the studs on the outer edge of the track.
