Yamaha Snowmobile Ski interchangeability???
Will 2005 warrior skis bolt up to 03 RX1? Got some in great shape for free. If so any choice of runners? I have had good luck with double downs on other sleds, but don't want this tank pushing
yes the 05 warrior skis will bolt up to the 03 rx-1. You will need the mounting bolt from the 05 ski as the 03 mounting bolt is shorter if i recall correctly. Both skis use the same skags, so you can use what ever runners you had for your 03 skis.
the one ton should not push the only prob i had was steering was too heavy. if you shim the skis that lessens i never needed dual carbides on my rx 1 ton either. duals will cause pushing to be more probable then singles. id try 6" stockers first. or longer if studded.
I am a fan of shimming the skies, I think it helps. Also if you get some pressure off the ski's you may want to remove some of the studs on the outer edge of the track.
