Fast_Eddy
- Vanderhoof (area) Canada B.C
- www.sledwest.net
I don't know much about them. First off are they reliable?
How much power do they give? Do they still work good in the mountains?
I have a guy trying to sell me his 2nd hand. ( he goin turbo)
He wants 2,100$ Canadian for the charger kit, boss seat, mrp header and tunnel dump exhaust, o2 sensor and gauge. With fuel excelerator.
He wants my oil tank and bottom side panels in exchange too
What are your thoughts
devinzz1
http://www.youtube.com/watch?v=w0ruO7GsN_c
if yamahacanada has a vid of it i guess they trust it
probably very reliable but minimal power gains compared to a proper turbo or supercharger cause it only makes about 2-4 pounds of boost. But with the extras adding to about $1300 your getting it for a great price.
little supertrax write up
http://www.supertraxmag.com/OEMarticle.asp?nid=19
yamadog1
tank
you will still need your oil tank, and the charger is ok but don't expect big gains, and they are pretty reliable.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Fast_Eddy said:I don't know much about them. First off are they reliable?
In the mountains it will be a waste, it only gives you 2 psi and you will lose any gains you got. The guy who is selling it to you mostly found this out and is moving to the turbo. I run a Super Charger and for the cost you are going to pay, you are half way to a supet.
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
I had one on my last sled and it is what it is! They made 20 additional HP over stock on every Dyno they were tested on and are pretty reliable. Run premium fuel and don't worry about it. Any thing more as far as boost goes and things get a lot more tuchey with fuel quality and fuel control. Just depends on you! How much money you want to spend? How knowledgeable you are with tuning as the bigger power will require more tuning and maintenance. As far as elevation is concerned a Turbo is the only thing that will somewhat compensate for elevation change. It is an option in-between.
- 7K
