xprtrpr
I bought new carbides last year, and my question is there a front and a back to them? Can I put them on wrong?
Thanks for the help
Thanks for the help
Oak Hill
- Dec 19, 2004
- Owosso, Mi
- www.airtoolexpress.com
There is a front and back to them. Where they turn up on the end at a 90 degree angle, that is the forward leading edge.
buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
Oak Hill said:Where they turn up on the end at a 90 degree angle, that is the forward leading edge.![]()
Huh?????
Travis Moore
buddah2 said:Oak Hill said:Where they turn up on the end at a 90 degree angle, that is the forward leading edge.![]()
Huh?????
Wondering myself here. I bought my sled used, and when I replaced the carbides I installed the new ones the same way the old ones came off (angle towards the BACK).
grader
when installed, the majority of the carbide should be behind the spindle.
WarriorBeads
- Dec 4, 2005
- Peterborough, Ontario, Canada
- 2004 Rx Warrior
Ditto to what Oak Hill said..... Depending on the manufacturer (and assuming you are refering to the rx ski), there should be a 90 degree bend in one end of the host bar. That is the front. Stock Yammy bars and Woody's Doolies are definitely like that.
As for the second part of your question, I don't think that they can be put on backwards, due to the way they fit into the ski....
xprtrpr
Well, I am still using a stock RX ski, but I bought Bergstrom skegs and I don't remember seeing anything that is like 90 degrees, they look almost symetrical from what I remember of looking at them.
Honk
The stock ski has the carbide up front with a small 90 degree bend in it. The bend go's up into the ski. In the rear the host bar is angled up so not to catch anything when in reverse. Remember that the stock nuts are metric, and when you buy new carbides they most likly will NOT be! So use the right nuts on the carbide studs, and the metric ones on the two other studs, that hold the saddle to the ski
buddah
- Apr 14, 2003
- Wetmore, MI
WarriorBeads said:Ditto to what Oak Hill said..... Depending on the manufacturer (and assuming you are refering to the rx ski),
Oops!! My Bad!! I've been running Simmons on my RX-1 (and Nytro) since day 1 on each and the slightly angled (tapered) part of the wear bar goes in front......but in doing that it puts the actual carbide to the rear. NOW I remembered what 90 degree angle you were talking about. NEVERMIND!!
Travis Moore
So the part of the carbide that is bent 90 degrees strait up goes towards the FRONT of the ski, right?
Travis Moore
TTT-please help
Oak Hill
- Dec 19, 2004
- Owosso, Mi
Travis Moore - The host bar, not the carbide.
