subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
Ive only had them for about 700 - 1000 miles and so far look brand new.... They also have an indention so you can tell when getting lower. Plus the cost is way cheaper. I want to say for 4 slides i didnt even pay 70 with shipping..
Subaru2006
Subaru2006
rayone02
- Dec 3, 2010
- adrian, mi
- 2012 Apex 2012 nytro xtx 2006 attak
Well Zx2 suspension is bought and adapter plates are purchased. What is everyone using for rivet gun? I have done tunnel extension was able to use hand rivet gun I think I better get a air rivet gun for this job.
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
I used a hand rivet gun with long handles.. those cheap guns you buy that fit in your palm will not cut it...
subaru2006
subaru2006
ZapeX2
Used a hand rivot gun and worked fine, mind you, you gotta man up and squeeze for all your worth but it works fine...
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
04Brian said:Used a hand rivot gun and worked fine, mind you, you gotta man up and squeeze for all your worth but it works fine...
Lol wish i could man up more.. Since i broke two of the smaller rivet hand guns..
Subaru2006
rayone02
- Dec 3, 2010
- adrian, mi
I found an air rivet gun for $44 good price that has good reviews. Going to pick one up when going to snow show.
Dano
Yep, save some grief and get an air rivet gun. I bent up 2 hand sets before smartning up and buying an air gun. Might even be able to borrow one in your area.
Dan
Dan
rayone02
- Dec 3, 2010
- adrian, mi
Ya I bought a long handled rivet gun. Long story short called store see if item was in stock they said yes. Arrived at store not in stock. I will just order one or buy one from ebay.
rayone02
- Dec 3, 2010
- adrian, mi
Just recieved Zx2 in mail. Few more questions just putting suspension together later. Should I use red loctite on bolts? What to use to keep limiter strap from moving thinking some pvc pipe? Any other info would be great before installation thanks again. What is everyone using to cover running board hole from clicker?
Just have to waite for 136 extension and adapter plate.
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
Locktite all bolts. I did. As for keeping The strap center I went and bought some clear silicone style piping that was just a little bigger Then the shafts. If you want pictures I'll post some but I think you get the idea.. as for clicker not sure because I had ec
Subaru2006
Subaru2006
rayone02
- Dec 3, 2010
- adrian, mi
subaru2006 said:Locktite all bolts. I did. As for keeping The strap center I went and bought some clear silicone style piping that was just a little bigger Then the shafts. If you want pictures I'll post some but I think you get the idea.. as for clicker not sure because I had ec
Subaru2006
Do you put the piping for the limiter on both shafts? just the top saft
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
Yes I made it long enough to cover entire shaft both top and bottom and cut the difference out(width of the strap). Make sense? Then place the two pieces on the shaft and both sides of the strap. Same thing for the bottom.
At work right now so I cant get a picture for ya. I'm sure someone has one or can find the post on this forum.
Subaru2006
Subaru2006
rayone02
- Dec 3, 2010
- adrian, mi
Ya I understand just wanted to know if you do top and bottom shafts.
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
Yup I did both...
Subaru2006
Subaru2006
ZapeX2
Rayone02.... did they give you a time frame for the extension? I was told Nov 9, sure hope it shows up this week, really want to get this thing together... I am putting on tunnel supports to cover the hole(i think)... I was also thinking of picking up a yamaha tuning fork emblem from ebay for there instead..
