stoutner
- Dec 6, 2005
- Seneca Falls, NY
- www.ecsexpress.com
Hey guys,
I installed my ZX2 according to instructions and notice that I only have 1/8" - 3/16" clearance between the lug on my track and the tunnel protector.
Anyboby else that has one installed, please let me know what clearance you have. 1/8" seems awefully tight.
I am running a Ripsaw 1.25" track. Sled is a 121" Apex. I can guarantee a 1.5" track would rub.
Did I do something wrong?
WarriorBeads
- Dec 4, 2005
- Peterborough, Ontario, Canada
- 2004 Rx Warrior
blurred vision mentioned the kit not fitting in his rtx, here:
not sure if this is the same issue he had???
Looks like his mount kit is for an RX-1, but he has an Apex and it won't fit.
I have a 07 rtx and the kit they sent me is for a rx1. They say its the right one but it is 100% not. Now they are looking at a 07 rtx and are going to get back to me. I decided to put a mono shock in. I have a gt and it rides really good.
Roadrunner
stoutner said:Hey guys,
I checked my stock 06 Apex ER and with the stock ripsaw track have 3/8" clearance measured right above the big wheels.
stoutner
- Dec 6, 2005
- Seneca Falls, NY
Roadrunner said:stoutner said:Hey guys,
Yes, I went to a Yamaha dealer last night and checked out a stock machine. It was about 3/8". That 1/8" that I have is gonna be really tight.
Anyone that is installing the ZX2 should do this...I think.
When you install the mounting plates you have a little "fudge factor". You should make sure you move the plates as far down as you can before you rivet them in. If you do this, you may gain another 1/8".
Again, I'm only talking about 1/8" so keep it in mind. You really can't go much more than that because you wouldn't be able to install the bolts because the heads would hit the foot rests.
I really can't redo mine because all of the holes are drilled. I would need new mounting plates to do this.
stoutner
- Dec 6, 2005
- Seneca Falls, NY
I e-mailed Jeff at AD Boivin and he said that the 1/8" clearance is what they expected and said that it is fine.
Sorry to make some of you worry.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Thanks for the update!
