Rx1M5, On My SCRX-1Mtn with whiteknuckle exaust which has stock style rear exits; I went for a location that gives me quick access to the sensor (if I need it) on the hill. Since removal of my BOSS seat takes all of 20 seconds, I installed the sensor centered on the front of the exhaust canister and angled it up ~ 45 degrees up from parallel to the tunnel,. I also cut an access hole in the heat shield. The wiring is all routed between the seat and tunnel to prevent and possible damage from a rotating track and ice build up under the tunnel.
Mac told me that my placement would give me a leaner indicated reading than what my A/F truely is during low engine rpms. He said this is caused by negative exhaust pulses alowing air back in the pipes because it is close to the exhaust exits. Better to be reading leaner than true operating levels instead of reading richer and risking engine failures.
Jim
