fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
How old is this kid? On side note the seat is why it rode terrible. If you can get the pleated viper seat it helps, the sx/srx pleated seats were best.
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
14
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Go over to the 2 stroke side Snobill. Lots of info over there. Mr.Viper (Don) knows everything there is about these sleds. I seem to recall a couple easy adjustments for reliability. Not sure what they were tho.
White & Nerdy
- Feb 22, 2019
- WI
- 17 Sidewinder LTX, 12 Vector LTX, 01 SRX
If I remember correctly, there is something that causes a lean condition if they are ridden at part throttle. They need the needles adjusted maybe? Definitely go to the 2 stroke site.
snobill
- Nov 4, 2012
- 2012 apex xtx
Ya I was reading something about that hopefully it’s not to late , compression was good so ...
NashRides
- Feb 11, 2018
- Maine
- 2007 Attak GT
This was Mr. Viper's recommendations for setting the needles on the Viper carbs.
The Viper has leaner carb settings then a SRX does, they use leaner nozzles, needles and slides, BUT.. they have way more ign. timing and a higher compression ratio, so this is a recipe for detonation with this crap they call gas these days. By richening up the needle you will make it slightly richer and most of the time this is where the viper will do a lean burn on the piston. Put the needle clip in the 4th groove down from the top but place both plastic shims on top of the clip instead of 1 on each side or under the clip. If you put them under the clip it will likely be blubbery sounding and not run very well in the cruise spot. By doing this your richening them up a half spot and help the mid range fuel mixture to be richer and have less heat resulting in less chance for detonation to start.
snobill
- Nov 4, 2012
- 2012 apex xtx
Awesome thanks ! that’s what I saw
snobill
- Nov 4, 2012
- 2012 apex xtx
snobill
- Nov 4, 2012
- 2012 apex xtx
I would have #*$&@ myself if I got this !
