ekmoor
- Mar 19, 2007
- Northern NJ - Ride in Southwest VT
Removed my main skid shock on my 03 RX 1 and found a non rebuildable shock. I have a 02 viper skid with shocks and they are rebuildable. Spoke to Pioneer and they said they would swap out the main (after rebuilding) with the viper and rebuild the RX1 front shock.
Any reason this won't work? Any differences in spring rate?
Thanks....Ed
Thanks....Ed
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
why not just change out the spring with the RX1 spring? i think the Viper spring is a different rate.
ekmoor
- Mar 19, 2007
As long as the diameter is the same (retainers work), I will keep the RX 1 spring. Sled is in VT, viper skis is in NJ...will find out this weekend.
03griz
RX spring does not fit on the viper shock. I tried.
ekmoor
- Mar 19, 2007
Did you try to do the same thing...but in a viper rebuildable shock into a RX1? Is it worth doing or forget about it?
woolyviper
- Mar 24, 2006
- hibbing,mn
03RX1 is a dual rate spring and if your viper is an er it has a single rate somewhat lighter - i think your RX1 will bottom fairly easily with the viper spring.
here's a link to the spring rates
http://www.totallyamaha.com/snowmobiles ... umbers.htm
Honk
I did the same thing back in 03. The 02 vipers came wrong from factory, so they let the viper owners change to new shocks. They did not make the stealer send the old ones back. I bought a set for fifty bucks, took it to pioneer for a revavle and still running it today 8 thousand miles later. Still find, you may need to play with the pre-load, but thats no biggey.
woolyviper
- Mar 24, 2006
- hibbing,mn
my bad - springs are close to the same.
ekmoor
- Mar 19, 2007
So Honk, you are happy with your revalved viper shock? Just pushed the preload a little higher.
Sounds like a go.
Thanks,
Ed
Sounds like a go.
Thanks,
Ed
dmaxx
- Apr 5, 2006
- sw Michigan
- 2014 Apex XTX, 2012 Apex SE, 2000 Vmax 700, 2000 AC Z-370, fast
- White Pigeon, MI
Go with the Viper shock, bolts right in. I used my revalved shock for two years, worked great. Huge improvement over stock.
ekmoor
- Mar 19, 2007
Shocks sent off to Pioneer on Friday....the main shock from the viper has some nice needle bearings instead of the cheapo plastic grommets that are usually crushed.
Hope to get them back this week.
03griz
Viper shock valved properly night and day difference....
