Travishanny
- Dec 21, 2018
- Hamilton
- 03 Yamaha rx1
i put a 3.5 inch riser on my sled. An got the powermad throttle extension kit on it but the cable is too tight it’s completely undone an still not enough sled won’t even start any thing I can do?
smallheadz
- Jun 27, 2018
- Central Ohio
- 05 RX1
Get a mountain cable
8FW-26311-00-00
8FW-26311-00-00
Anjill
- Mar 20, 2015
- NJ
- 2004 Warrior
2006 Attak
2013 Apex X-TX
If you installed the powermadd cable extension and it's too tight you've done something wrong. Maybe you routed the cable incorrectly?
Travishanny
- Dec 21, 2018
- Hamilton
- 03 Yamaha rx1
That will be long enough? An fit?Get a mountain cable
8FW-26311-00-00
Travishanny
- Dec 21, 2018
- Hamilton
- 03 Yamaha rx1
The cable is plenty long enough it’s just pulling way to tight on my throttle from the cable inside. It’s really hard to explain. You would almost have to see itIf you installed the powermadd cable extension and it's too tight you've done something wrong. Maybe you routed the cable incorrectly?
Anjill
- Mar 20, 2015
- NJ
- 2004 Warrior
2006 Attak
2013 Apex X-TX
Interesting...I've used both the mountain cable and the cable extension and both worked fine. Let us know how you fix it. Good luck.
superfan75
- Sep 12, 2013
- West Topsham Vermont
- RX Warrior
I'd like to see how people reroute there cables for 3 1/2" bar risers. I have a 2" pivot riser with a 05 rx mtn throttle cable and there isn't much cable left. I'd like a 3 1/2" to 4" riser with my Apex seat, but I'm not sure about the brake line and parking brake cable. I'd really want more if I get a WRP seat. I have back issues and anything I can do to make my sled more comfortable the better.
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
What part number did you use?should have been#43595 &has very specific fitment instructions for 4 stroke yamaha.did you cut the white piece off the throttle lever barrel end?i put a 3.5 inch riser on my sled. An got the powermad throttle extension kit on it but the cable is too tight it’s completely undone an still not enough sled won’t even start any thing I can do?
used an 05 rx1 moutain cable on my 05 rx war when i put the 4" on and on my brothers when it got the 4" rox riser on his 04.
Fortress
- Dec 18, 2016
- West Canada
- 2004 RX1
Ya I put a 2" riser with the 2005 mountain cable on my 2004 rx1 and there wasn't much left.....you might want to switch to a 2"
cable might have been mislabled for you fortress as i ran the 05 mtx cables in stock location with lots of room to spare on a 4" riser.
