Claw
- Feb 16, 2021
- Lake Tahoe
- Rx1, Rx1, Summit 800, summit 600, Summit 600, Summit 600 Summit 800 Summit 800, Summit 800, Summit 600, Renegade 600, Mountain Max 700,
Hello all. New to the 4 stroke area but not new to Totally Yamaha
I have 3 RX-1s and I really can't get them to run perfectly.
I am really close on 2 of them.
The 3rd however, I am really scratching my head and I don't want to blow the engine.
I am somehow getting fuel in the oil. Like a LOT.
The sled fires right up and sounds great. Go for a ride and the idle then goes all over the place and the oil tank fills to he top with an oil fuel mixture.
I thought the needles were stuck open, but replaced all the needles and when I have the carbs filled, I cannot blow through the hose. (not sure if this is a proven method for that)
Ive replaced the oil 3 times now and I can't keep doing that.
It also seems like cylinder #3 (if you're on the sled looking down its the 3rd from the left) is not firing properly.
I pull the wire when it running and I do not get a stumble like I do when I pull the wire to any of the other coils.
But when I pull the plug and check the spark, it fires just like the rest. So confused. Maybe its not getting fuel and thats why theres no stumble???
Ive tried 4 different coils and all do the same
Sorry for the long post. More info the better I am thinking.
Very much appreciated for any help or direction
