fasted
After 6000 rpm it feels like its running on 2 or 3 cyl. It will only rev to maybe 8000rpm. This is what I have tried.
New Plugs
Compression 180 +/- 3 psi all 4 cyl,
Cleaned Carbs twice
Swapped all 4 coils with another sled
Checked TPS
Bypassed fuel pumps and Tank with an aux, Tank when I sync, carbs
Check Clutching all good (even ran without belt not smart just getting desperate)
Can turn Track by hand also (nothing binding)
Disconnected TORS
This thing falls right on its face when you give it more than 1/2 Throttle. It idles great and start great But I'm lost Need help!!!!!!!!
New Plugs
Cleaned Carbs twice
Checked TPS
Disconnected TORS
stephenk
What color are your plug tips?
fasted
The plugs are med tan in color not wet or any thing seem to be burning fine.
fixerman519
Dumb question but do you have a mouse issue? , I had something similar and there was a monster nest in exhaust, idles great would put around fine but fell on its face and almost died when I tried to rev up, just a thought , best of luck
fasted
We just got back from a trip and it ran fine parked in garage. Started it up a week later and it did this.
cv slide sticking or broken coil?
fuel fiters bad?
fuel fiters bad?
fasted
cv slide sticking? explain maim please. I swapped out all 4 coils no difference and bypassed the fuel tank and fuel pumps no difference.
the black caps on the top of the carbs are for the vacum operated carb slides. there are springs in there to hold them in the down position.
could also be a vac leak from one of the caps or O-rings at that rpm. if you have acess to another carb rack, try it and see if your problem goes away.
Check under the tool box in front for the cable running over the frame for rubbing through. If that is not the problem use some zip ties there to prevent it from happening in the future. Next switch out the CDI from a sled without this problem. If that is not it I would clean the carbs again making double sure all the jets are in the right places. Some peeps have got the main jets and power jets mixed up.
fasted
thanks for input . I don't have access to a carb rack or cdi unless a cdi off a 06 apex will work. I will have to check.i will look under tool kit box for any wires bad and take apart tops of carbs and look for any issues. the switching jet issue is not, this did this before I cleaned carbs. it ran great before . I will do this this afternoon when I get home from work.
fasted
So I checked under tool holder and there was no wires rub threw but what I did find was one of the plugs on the rectifier/regulator broke and the wire partially on. I guess my daughter rear ended a sled and smashed it. My question is does anyone think this could cause the problem I have described? Also I checked the tops of the carbs and the rubber boots with the slides look good.
