Brian A
- Feb 17, 2014
- Farmington Hills, Manton Mi
- RX1
Being a retired auto mechanic I have been into many carbs ( just to make you aware I know my way around a bit
While waiting on my WRP seat kit to arrive I am cleaning the carbs for the first time since I have owned this sled. Looks like they have never been opened up before
Question is the O ring on the main. Mine are deformed and brittle, I cannot reuse them
I am going to try to find replacements at work tomorrow
I did a little searching and it seems they arent really needed? Is this true? Some people are putting it together with no o ring?
This isnt the mountain carb setup, there is no shield just an o ring
What is the consensus here? I can take a pic but I dont think its necessary
Regards
Regards
Brian A
- Feb 17, 2014
- RX1
I found some o rings here at work
I cannot imagine them not needing them
RobX-1
- Coldwater, OH
Brian A
- Feb 17, 2014
- RX1
thank you Rob!
Brian A
- Feb 17, 2014
- RX1
got it back together last night. Running fine again
First time I have had carb issues with this sled, owned it for about 5 years
Carbs are really easy to clean, the problem was the tiny hole in the pilot jet was plugged which I have learned is a common problem
