Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
I was changing main jets on my Warrior today and upon removing the float bowl I noticed that little O Ring right above where the main jet is screwed in was cut! How important is that O Ring? Can you run without it?
Turbo Tim
Bob Miller said:I was changing main jets on my Warrior today and upon removing the float bowl I noticed that little O Ring right above where the main jet is screwed in was cut! How important is that O Ring? Can you run without it?
Dont climb any steep hills without it .........
YamahaRx-Warrior
Just get a new one and change it.
GreenMtnRx1
If those o-rings don't seal perfectly the engine is not going to run very well at all. THEY MUST SEAL!
Bob Miller
- Apr 19, 2003
- New Milford CT
Thanks! I changed them! I got 2 packages of assorted o rings with about 50 different o rings from the auto part store in there HELP selection for $6.
It would take a while to get the Yamaha replacement, and get this: those teenie o rings are $2.97 each!
:itchy:
:itchy:Similar threads
