jrice1987
- Jan 25, 2019
- 2003 Yamaha rx1
I get the track aligned but as soon as I start the sled and rotate track a couple times it goes back to being 1/4 In off?
olivia317
- Jan 20, 2013
- Olivia, MN
- 2012 FX Nytro XTX SC
Keep the rear axle bolt snug, just loose enough for the adjusters to move. This will take any play in the rear wheels out of the equation. I quarter turn on the adjuster can make significant changes. I always start with the nuts flush with the end of the adjuster and count the turns as I tighten. Keeping them equal until I get my desired tension. Once tight, take baby steps until aligned.I get the track aligned but as soon as I start the sled and rotate track a couple times it goes back to being 1/4 In off?
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
Put a 1"square stock between the track and the skid. Tighten up to it. Then fine tune it from there.
jrice1987
- Jan 25, 2019
- 2003 Yamaha rx1
If I move one adjuster or the other it make different tension on each side
jrice1987
- Jan 25, 2019
- 2003 Yamaha rx1
So how is possible to adjust one or the other to align it?
jrice1987
- Jan 25, 2019
- 2003 Yamaha rx1
Tension will not be equal on both sides right
i usually end up one turn (average) more on one side to get the track to run square on most of my sleds.
