04 Warrior, Bad CDI ?
DV8
Howard City MI
Attack and Axys
The handwarmers stopped workling on my warrior, So I tested the grips, even though they are brand new, grips test good. No warning light. Tested handwarmer switch, it tests good, Test grip connection beneath handle bar pad, it too is good. I checked the Cdi connection, blew it out, nice and clean, No change. Everything else works, thumb warmer, lights, just no handwarmers.
When it starts it does flash the grip and thumb symbol with full bars on the right side like it should, but after that nothing. If I am reading the wiring right they go directly to the CDI box, no fuse or relay.
Any one have any thoughts?? Checked the harness also, dont see any rub thru only has 4600 miles on it.
Anyone live around here that has a extra CDI thats good I could test with before I buy another one?
Sand Lake MI 49343
After playing with the meter for a few hours, The CDI is working, the outputs are good. Just the speedo gauge doesnt show the handwarmer level. I can deal with it for the season, At least they heat up and work.
Speedo
I have a RX gauge with 916 miles on it if you are interested.
